Wheel chock
Old 03-14-2014, 08:32 AM
xdanman's Avatar
xdanman
xdanman is offline
Default Wheel chock
I bought a new lift table from harbor freight and got their more expensive wheel chock. Th bike was not running at the time because I was doing inner fairing work. Anyway I could not even push the bike into the thing to get the front wheel locked in. What kind of chock does everybody have and do you guys like it. Need some advice.
Old 03-14-2014, 08:41 AM
squaredaway's Avatar
squaredaway
squaredaway is offline
You need the black one. They have. It has the tail you drive over.. Bolt it down about 3 inches over the front of the lift.
I usually drive up. But once its in . no straps.. no problem. See if I can find a pic.
Old 03-14-2014, 08:44 AM
squaredaway
I guess this is the only pic I have.. You can see it...
It is for setting on the ground. It has a cross bar that you don't use. Just bolt it to your table.. I don't know what I would do without my lift.
Old 03-14-2014, 09:45 AM
jamess71's Avatar
jamess71
jamess71 is offline
And if you do have the black one that's been mentioned make sure you adjust the back stop in one hole, so the chock is a little smaller. Keeps the front wheel up a bit but makes it a lot easier to get the bike in and out of it.
Old 03-14-2014, 10:00 AM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,481 Likes on 1,540 Posts
yep, the black one is the one to have and do like the above post says and you'll have no problems.
Old 03-14-2014, 10:12 AM
xdanman's Avatar
xdanman
xdanman is offline
Default Re
Ok, that is good. I do have the black one, but I must not have had the rollover part pinned up enough. I felt like it was going to hit my fender.
Old 03-14-2014, 10:45 AM
472viper's Avatar
472viper
472viper is offline
Harbor Freight black, my bike (08 SG) sets in one all winter.
Old 03-14-2014, 12:48 PM
rbferg's Avatar
rbferg
rbferg is offline
I have the Condor trailer chock and it woks great. Best chock out there and they have several models.
Old 03-14-2014, 01:17 PM
drm0's Avatar
drm0
drm0 is offline
Default Wheel Chocks
For on the floor or trailer I use a Condor Chock. Great product!! Adjustable for most tire sizes, light and sturdy.
The chock on my table(Direct-Lift) is simple but effective. Hand crank to "pinch" the tire so no tie down needed. Jaws have rubber padding so will not damage the wheel.
drm0
Attached Thumbnails Wheel chock-2014-03-14-12.55.43.jpg   Wheel chock-2014-03-14-12.56.06.jpg
Old 03-14-2014, 01:22 PM
472viper's Avatar
472viper
472viper is offline
That's the vice that HF table lifts used to come with, then they cheapened them up a bit.
I do like a wheel chock though, ride up step off. I don't strap mine unless I'm wrenching hard.
Quick Reply: Wheel chock
