Bike will not start after Ape install
Old 03-14-2014, 07:06 PM
klimoman's Avatar
klimoman
klimoman is offline
Question Bike will not start after Ape install
Bike: 2009 Electra Glide Ultra Classic
After read the other posts on this topic I am assuming it may be the TBW as the issue.
All electronics work, lights, radio, etc. and the fuel pump kicks on when I twist lock to ignition. I pulled the spark plugs and I am getting spark so I figured it was a gas issue. I squirted a little starter fluid into the carb and it fired immediately.
While doing the install I purchased a new TBW to get rid of the pesky green connector inside the bars.
My plan of attack is to remove the fairing tomorrow to double check the connections of the TBW at the plug. Is that the way to check the TBW?
Is there another way to check to see if the fuel is blocked elsewhere first?
Any other suggestions?
Old 03-14-2014, 07:12 PM
Hogleyripper's Avatar
Hogleyripper
Hogleyripper is offline
I would check every connector that you touched. It could be as simple as not pushing a wire far enough back into the factory black connectors. Your bike ran before it should run now. No need to get crazy with squirting fuel. Something just isn't plugged in all the way.
Sent from my iPhone using IB AutoGroup
Old 03-14-2014, 07:14 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,235 Likes on 999 Posts
Did you remove the tank? Did you reattach the quick connect fuel line? I know it's a dumb question but sometimes it's the simple things we over look.
2010 Limited with some stuff
Old 03-14-2014, 07:15 PM
Northbound Southerner's Avatar
Northbound Southerner is offline
I agree...tbw will not keep it from starting. This is not an electrical problem. I would be willing to bet you have the quick disconnect connect wrong...I've done it before...pull it and reattach...
Old 03-14-2014, 07:20 PM
PistonPuller's Avatar
PistonPuller
PistonPuller is offline
You have a 2009 with tbw and carb?
Old 03-14-2014, 07:25 PM
Ha...I missed that...I hope he meant throttle body...
Old 03-14-2014, 08:34 PM
SBates08's Avatar
SBates08
SBates08 is offline
You get it figured out yet?
Old 03-15-2014, 09:59 AM
klimoman's Avatar
klimoman
klimoman is offline
No carb, meant shot starter fluid into butterfly of throttle body. My bad.
I am just starting looking at all the connections this morning...
The quick disconnect was connected to the tank. With me, there are no dumb suggestions, I could have overlooked anything.... LOL
Once I get it started I will let you guys know. What the issue was. Keep the suggestions coming because I need all the help I can get. :-)
Old 03-15-2014, 10:06 AM
WillyD's Avatar
WillyD
WillyD is offline
I just did my bars on my RK...I had a similar issue...under my dash the three prong plug I had bent two pins when I re installed it...straightened the pins and wallah...it started..I thought I heard my pump running too but it wasn't right with the pins bent...I know you don't have a king but just something that simple (not visible when it was plugged in) can screw things up...
Old 03-15-2014, 10:19 AM
Did you pull the quick disconnect and reinstall? Sometimes it doesn't connect right but will look fine...
Quick Reply: Bike will not start after Ape install
