ape hangers on 2014 STREET GLIDE
Can anyone else confirm that the stock brake and clutch hydraulic cables will work for 12" apes?
thanks,
Wes
thanks,
Wes
My brake and clutch lines were ok. I installed the the new ones since they were stainless braided ones
I have the 12" stainless steel kst bars
I used the la choppers kit from jp cycle. It comes with banjo bolts copper washers clutch line. Brake line left and right brake lines
I also used namez wire extenders.
Unfortunately I ended up cutting and soldering the throttle by wire line because with the other wires going inside the bars I ran out of room and the factory connectors wouldn't make it through.
I have the Avon heated grips but I can't figure them out so I'll be sending them back to get regular grips.
You need to bleed the clutch line which was ok. I needed to loosen the exhast to get the trans cover off. The brakes also need to be bled. That's where I'm at now.
If you have basic mechanical knowledge and a good memory you can do it. It will save a bunch of money if you do it yourself.
I think I paid close to $800 for the parts. No where close to $3000. You will need to pick up some brake fluid from HD
I like that look I want to do that to my 2014 SGS soon. I was going to have the dealer do it when I purchased the bike so that it would all be covered under warranty. The price was not that bad if I remember correctly it was about $1300.00 for 12" bars and wire extensions. But when I asked about getting all of my stuff back that they would be taking off. They said what ever they take off they keep! So I passed on that.
