Tuning a 2004 Road King
Contact Power Commander, or check on their website, for a local PC-approved tuning shop. I don't believe he can't get his PCIII right!
I want to use my PowerVision on my 2004 Road King but with no O2 sensors, it cannot do autotune on it. Unless I get new headers and the Autotune kit, which I cannot afford yet. But I got a used FuelPak (model 61003a) for it and now it is running great. If he can find a used one, that is a cheap alternative to try out.
I had several maps on my '99 RK, still had the ping...
Mostly on highway, at above 50mph, when attempting to speed up. I rolled the throttle a bit, and pinging would start. Let off, ping stopped. Changed a couple maps with jaimie, but still pinging.
I looked at the timing table, and the last two rows were set at +3 (actually just 3). I edited the map a couple times, (saving the original just in case). First change was to change the timing in the last two rows to '2' (still pinged), then second change to '1' (still ping). I believe I ended up with a '-1', in the last two rows. And that seems to have 'cured' my ping...
FM are also an HDF sponsor and get good reviews on here, so hopefully they will give you some useful advice.
