It takes 45 to fill back up if you pull the inner and outer covers. Just draining doesn't even get it all. Pull the outside cover and it will leak out lots more.
Stop pouring oil in the primary when the oil touches the bottom of the clutch basket. You will probably have to shine a flashlight in there to see really well. If you get a little too much in there (an ounce or two) it won't hurt anything.
And if you get more than an ounce or two? I got mine a little above those clutch wheels. Think it might have been a little much.
You'll void your warranty! J/k.
If you have too much, you might experience a slipping clutch. It's not a huge deal, and if you're worried about it, drain and refill to the correct level. Nice thing about the primary fluid is that it's really easy to deal with.
That's the best way. You only need enough to keep everything wet with with oil as you ride. This is NOT a crucial deal. HD publishes figures for fluid capacities. But that doesn't mean everything needs to be filled to capacity to prevent damage.
