Vance & Hines Fuelpak FP3 installed!
#51
#52
Sounds like, for the most part, positive reviews. Has anyone used the Autotune feature yet? Mine is currently in the Autotune mode and I am getting the slow flashing red security light. The code, per the FP3 look up feature says I have lost communication with the ECM, so I am thinking this is just part of the Autotune function. Any ideas? Am I thinking in the right direction. And if it matters, it is a 2014 Street Glide Special.
#54
#55
Vibration
I just installed V&H power duals, hi output carbon slip ons, V02 air intake and the FP3. Since tuned with the canned map, I'm getting less heat and it runs good however at low mph I get a pretty good vibration until about 30+ mph and then smooth. When decelerating I'm getting some pops too. Anyone else have these issues? I'm considering the auto tune but giving the problems I'm a bit cautious at this point. thoughts?
#56
#57
I was wondering how long it would take for someone to acknowledge the P is for Pursuit Lights on a Police bike and has nothing to do with a Parking brake. Only bikes with that are trikes. I just ordered my FP3 from Eastern Performance today. I'll select a canned map for the closest V&H pipes to my Freedom Performance upsweeps on my 2014 DeLuxe and go with that. I'll try the autotune function later.
#58
I've read every post here and have a cpl questions. I have a 2014 CVO RK with the FP3. I have decel popping with the VH map. It has twin round slip ons.
So, based on some of the troubles I've read I'm hesitant to do the autotune but think I should. Would you guys recommend remapping back to stock before autotune?
Also, I had it plugged in for a whole tank of fuel already but didn't realize I needed to turn autotune on... I'm not sure how to do it. And what happens if I stop and get off for a while? Do I just reopen the app and turn autotune back on?
Thanks!
Nick
Thanks!
Nick
#59
Run Autotune off current map. It "fine tunes it" according to V&H.
The app and phone has no influence on autotune. It "turns on" the FP3 unit to autotune mode, display's info from FP3 regarding cells learned, and then tells the FP3 when to finalize the map. You don't even need to bring your phone when performing autotune.
I ran Autotune for approx. 250 miles in 3 seperate runs that were saved (used the phone to tell it to save an apply learned cells) after each run. Once the third run was done and I was happy, I told the FP3 to "finalized" the tune via my phone. This then saves the learned data to the ECM. It will also create a new third map in your available 6 slots on FP3 unit.
The bike will run bad when in autotune. If it does have an occaisional decel pop after finalizing tune (NOT a backfire) then it is not a major concern. Hell, it is actually considered normal for a properly tuned engine with reduced muffled baffling. Read this article to alleviate any misconceptions regarding decel pops. http://wildfirehd.blogspot.com/2011/...opping-on.html
#60
