head gasket leaking oil
I believe I have developed a head gasket leak - oil is dripping out of the area below the rear rocker box - I recently had the rear rocker box replaced with new box and gaskets. 2009 RG with Head-Quarters 107 - 41k miles - does anyone have an estimated cost of this repair with labor from the indy being $60 hour. thanks
I believe you mean you developed a rocker box gasket leak instead of a head gasket, yes? If you "recently had the rocker box replaced with new box and gaskets" may I ask who did the repair? If it was fairly recent and a dealer or indy replaced and is now leaking, they should fix it. In any event, it will be about 2 hours for a repair plus the gaskets.
