Brembo Brake Caliper Question
Has anyone swapped out the two bolts that hold the Brembo Calipers together for chrome bolts while still on the bike?
I want to swap them along with the caliper to fork bolts for chrome.
I'm thinking I can swap them one at a time without splitting the caliper and causing a leak, but not sure if I'm playing with fire here?
Thanks in Advance!
Thanks in Advance!
I used Qty:2 Drag number 2401-0224 Diamond polished stainless caliper hardware kit. It gets the caliper hanger, and actual caliper hardware. This alone looks fantastic, but if you feel the need to replace the banjo hardware H-D sells the banjo bolts and you will need to bleed the brakes
Cityfyrman
02-20-2009 08:46 PM
