Primary fill on 13 Limited
03-24-2014, 04:47 PM
In the Service manual it says to add 38oz to wet primary or 45 to dry primary. I just drained it. Would it be considered wet or dry? I'm assuming dry would be if it was new and never had oil in it.
Thanks!
03-24-2014, 05:03 PM
It would be wet, dry is no oil has ever been in it.
just draining and adding new fluid is "wet".
03-24-2014, 05:05 PM
Just like foreplay...she's "wet."
03-24-2014, 05:29 PM
Don't just dump 38oz's in. Put in 1 quart and check the oil level as per the manual. Then add till the level is where is indicated in manual.
03-24-2014, 07:00 PM
I found if i put 38 oz in it is ok, if i fill it by the picture/desription it is overfull and the clutch drags. Mike
03-24-2014, 08:57 PM
Thanks guys. That's what I figured!
Glideride78
01-14-2017 11:34 PM
JONNIEROCK
09-02-2016 08:33 PM
ROADKING861
02-06-2012 04:14 PM
a34655
05-23-2009 07:51 AM
cwickgo9
04-27-2008 09:43 PM
