Bad oil pump?
Bad oil pump?
Oil blowing out of breather tubes I on 96 ultra classic fuel injected been riding all winter not setting at all it will suck the oil tank dry replaced umbrela valves new checkball valve and spring drain all of the oil checked all lines they are clear could a bad oil pump cause this?
in the cam chest.
go to ronnies
http://www.shopronniesharleydavidson...partfinder.htm
click on motorcycle, select year, model, then crankcase gear side, and you'll see it
mike
go to ronnies
mike
