Bike running like poo
Greetings,
I have been having issues w/my bike running bad. The symptoms are identical to the speed sensors issues. Put a new one in & a hair better , still "off".
If I was to install a PC V & having a clean map by a dyno, guy would it help?
I am the 2nd owner and only know that the bike had a SE tuner loaded when he bought it, pipes, and air cleaner as well. Thank you.
So what exactly is it doing? Why can't the indy dup, is it intermittent? Sometimes more info helps. I know most people think that if they give too much info it will cost more but that is wrong. There are several things that can cause the same problem & the one thing you leave out on what it does might be the decifing factor on where to look.
Toby
Toby
1blackz28
02-20-2014 05:33 PM
