How do I know if I have a Stage 1 upgrade?
Bought 02 Ultra used. PO had passed and I bought the bike from his wife. She doesn't know anything about it. Had slipon's and SE air cleaner. So I'm assuming it had a stage 1. Upgraded pipes to V&H Propipe 2:1 and bought a used V&H fuel pack. V&H tech guys give me a map to download based on a stage 1 being installed on the bike. Getting a lot of vibration and not seeing a HUGE amount of performance improvement. Also getting some pop on deceleration BUT the bike runs much cooler. I wondering if I should install a map for a completely stock bike. Is there a way of checking to see if my bike has a stage one download?
have you checked under the seat/side panels for a fuelpak or power commander unit?
also, it may not have a standard harley stage 1 download, it could have a race-tuner job done at a dyno shop like mine did. i had the harley dealership check into it, and all they could tell me was that it had been tuned by someone, but it wasnt a HD tuner.
The stage 1 download isn't going to have a lot of affect on decel pop or vibration. The stage 1 only adds a couple degrees in idle area and 10 degrees in the high decel area and takes away 1 to 4 degrees in the cruise area and high load area. It only adds fuel in the wot area from 3 to 6%. If the vibration is happening under load and in low rpm area I would try having a richer map from idle all the way up since you are not seeing any improvement. Lean condition can cause the vibration. If you can update your fuelpak yourself I would add 5% more fuel. The Propipe is a fine exhaust and it does lean the bike out. All 2 in 1's need to be richened up. The vibration can also be caused by loose motormount or bad, or loose brackets on the exhaust and such. That decel pop is good indicator the engine is lean and lack of performance is probably lean also. If the plugs and wires haven't been changed I would consider doing that also. That won't cause the decel pop, but can cause vibration and poor performance. May also want to have fuel filter and or pressure checked and air leaks around the intake.
Today this is called optimization.
Bike revs up to 6K RPM without any problem so pretty sure I have a stage 1. I installed a Smartpartz quiet baffle to quiet up the Propipe a bit and thought that would make it run rich, but that's not the case. The V&H tech gave me some new values to change on the Fuelpak so I'll give that a try. These Fuelpak seem to be the best option without major engine upgrades, so I'm trying to keep an open mind.
