Tire for tire change
04-10-2014, 12:27 PM
This is a dumb question but I have a new tire (front) Can I put it on the rear if I reverse the rotation? Safely
04-10-2014, 12:32 PM
If it is the same size, I can not think why not...
04-10-2014, 12:35 PM
If its the same size and non directional go for it, otherwise follow the proper rotation indicated on the tire
04-10-2014, 01:13 PM
Front tires and rear tires are a different design and not interchangable. The rear is design for braking loads and driving loads.
04-10-2014, 01:14 PM
just make sure it has the proper load rating
04-10-2014, 04:00 PM
Really depends on the brand. Some tyres are dual purpose and can be used either end, but some are very specifically intended for front or rear. Wotyagot?
04-10-2014, 04:05 PM
Quote:
Originally Posted by
03 Fatboy
Umm, and what is the front tire design to do?????
04-10-2014, 05:05 PM
turnerbend
just brake, so loading is only in one direction. some tires take advantage of that fact with the way the plies are laid down.
OP: the tire will say on the sidewall if it is front wheel only.
04-10-2014, 08:38 PM
Dunlop
grbrown
I was.told to reverse rotation, the frt. For breaking and the rear for power.opposite rotation.
04-10-2014, 08:40 PM
I do not think this is wise. I would not do.
