Hydraulic Clutch - Can it be adjusted?
Received 3,389 Likes
I appreciate the comments so far. I don't think there is a problem with a clutch although I will ask the dealer when I take it in for the 1k. I have small hands which probably doesn't help. After sitting in stop and go traffic, my hand was raw. There is a pressure point that still feels bruised today. Perhaps I just need to build up the strength but I never had this issue before.
There may be something wrong with your clutch mechanism. My sig bike gives me no problem at all in stop and go traffic, and is markedly easier to pull than my last bike was (`09 Dyna SG, a cable clutch). That being said, I always put the bike in neutral when stopped for a long time at a light after the vehicle behind me was fully stopped.
the Hydraulic clutch is the unit in question here.
the clutch wiz unit reduces clamping force on the clutch assembly, similar to simply swapping to a lighter spring.
so slip is more possible.
mike
mike,
from what i've read, the clutchwiz does work with the hydraulic clutch but you need to add the stronger spring or it will slip.
thinking of this myself, my hyd clutch is harder to pull than the cable clutch on my 2010, though i did have the aim vp92t installed after doing the 107 kit.
Originally Posted by clutchwiz
CVO® and Hydraulic Yes, the ClutchWIZ™ will work on Hydraulic clutches and they can be adjusted if necessary. Simply bleed the hydraulic system a few times like you would your brakes. Doubt you will need to make any adjustments on the CVO®.
(CVO® riders...Remember to upgrade your spring to the 480 will work just fine...)
http://clutchwiz.com/Installation.htm(CVO® riders...Remember to upgrade your spring to the 480 will work just fine...)
Herbkell (03-31-2021)
