Radio on no sound from speakers
The issue I have a 09 HD UC Today while riding I was listing to my radio and the speakers go dead no sound at all the radio is on and still showing stations etc... I change stations still no sound CB is off...I start playing with the speaker switch on the faring cap and they go back on this happen several times during the course of the day until I finally got tired of it and shut the dam radio off.. Anyone have this problem ideas Thanks Joe
Not the speaker switch. Your HU has suffered vibration damage, Over tine the sound will go out more often till one day it will not come back. I was flipping that speaker switch on my 08 for about a year. Your solution to your issue is Iron Cross Audio. Do some searches and you will find this is a common problem with the HK radios. When you have the outer fairing off check your fairing brackets. More than likely one if not both are busted(another known issue). This more likely than not caused the vibration damage to your radio.
Here is a link to Iron Cross.
http://www.ironcrossaudio.com
F150HD (07-10-2022)
good call Dave ,,,,, www.ironcrossaudio.com ,,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Just had mine repaired, yes vibration issues within the HK radio. I had Iron Cross Audio do mine and while there had the backlighting changed also. Tony is the man on these type of repairs. I changed out the riser bolt on the handlebars while radio being repaired, he will talk you through this. Give em a call and you can be back to jamming.................
Regardless, after reading this post and radio with no sound, I pulled the radio from my 2012 and swapped it in and viola, I heard music.
Now just need a replacement radio for my 2012, will do some reading. Seems like that bracket has a ripple effect of damage under the fairing.
davessworks
07-04-2013 09:55 PM
