removed inner to replace shifter shaft arm now starter will not engage all the time , if it doesnt I have to roll the bike back and forth to get the jackshaft to engage. What do I need to do to remedy this, any help would be appreciated
Reason: spelling
first check the wiring to the starter to make sure it is tight and clean, next I would loosen the starter a few turns of the bolts and see if you can move it a bit and retighten it....next I would check the battery to make sure it is charged and up to snuff....
