Tire cupping
....along with the fact that Harley doesn't give good enough guidance on them IMHO! The pressures in the owners manual should only be taken as a guide. If you are heavy, or ride 2-up a lot then add more air, according to taste. I use book pressures when solo, for 2-up I add 2F/4R and when fully loaded in touring mode I use solo plus 4F/6R.
My tire pressure is checked once/week, both front and back. I have MC2's and go with 40PSI in both just so I don't forget which is which. No problems yet. I used the same method for my stock Dunlops and ended up with 15000 miles and no cupping issues. It's all about the pressure I think.
Besides tire psi being some of the issue, I believe the forks and rear shocks play a bigger issue causing cupping. Usually cupping on an auto is from weak shocks and the tires dribble up and down going down the road, the same theory holds true with the rebound/compression of the forks and shocks.
How many HD's have precise suspension adjustments? Not too many, throw in the fact that majority of folks dont adjust their air properly and it goes down hill from there. FWIW, once a tire wear pattern is started (even when you cant see it starting) it only accellerates wear and theres nothing one can do to stop it.
