Any ideas? Sounds like a trip to the dealer. I'd rather not go there after the last time. I may take it in to the only other dealer in the area about an hour away if I really need to. My ESP is expiring in June.
You can't see the wire broken because it is only broken inside. The insulation will be fine. It is right where the cable tie is. Maybe it is too tight. That's where my problem was. Good luck.
Thanks,
I'm going to look closer this am, last night I looked at the connector with a flashlight it looked ok but I did find a cracked wire near the zip tie, It is a coaxial cable that I figure must be the antenna wire. Will update later.
Thanks all, It was a broken wire right under the zip tie, Took me about four hours to fix but I pulled the fairing the tank, bags and sidecovers and did some cleaning while it was stripped naked. The antenna didn't survive, going to order a hidden fairing one.
