Barnett clutch owners
04-20-2014, 07:33 PM
Big Kahuna HDF Member
What primary oil do you run?
04-20-2014, 10:17 PM
ATF, dextron II or B&M trick shift
04-20-2014, 10:30 PM
b&m trick shift, original
04-20-2014, 10:32 PM
Atf. In last bike! Just put in extra plate Barnett clutch and aim pressure plate,today! Used ATF again as it worked fine last time
04-20-2014, 10:34 PM
Nothing fancy here, just Formula +.
Jeff
04-20-2014, 10:51 PM
Quote:
Originally Posted by
akjeff
Jeff
Is this the HD oil that Barnett says definitely do not run?
04-21-2014, 12:17 AM
bigfish_Oh
When I talked to Barnett's tech line about my Scorpion clutch, they said that Formula + would work just fine. I only have a couple hundred miles on the new clutch.....will have to see how it goes.
From Barnett's F.A.Q.
"Q: Can I use synthetic oil or a synthetic blend with a Barnett clutch?
A: Yes. Barnett clutches are designed to work with any type of “motorcycle specific” oil. We DO NOT recommend the use of automotive oils or additives."
Jeff
04-21-2014, 06:08 AM
The Wiz recommended Formula + and a bit of ATF mixed in. That's what I did, seems to work fine.
04-21-2014, 08:09 AM
Thanks, also did you use the Barnett spring? Or OEM ? Or reuse the original?
04-21-2014, 08:58 AM
Several friends using syn3 with their Barnett cf clutches. They use them for slow riding skills - cone competitition
