Evo cam ?
there is an evo forum where you may get better help, most of the Guys here have late model bikes
there are at least 3 evo cams that i know of from H-D.
California, 49 State and the police cam ( like an Andrews EV23)
and then all the aftermarket, S&S, Andrews, Jims etc.
you'll want to replace the inner cam bearing to a torrington
if you want to leave the heads on, get adjustable pushrods, cut the old ones out with bolt cutters
new lifters probably a good idea
if you take the heads off, you can use the stock type pushrods.
you may want to do this if you have any base gasket seeps to fix
I hope you have a carb
mike
mike
