4 point docking system in the way
Old 04-23-2014, 11:34 AM
swampfox_csa's Avatar
swampfox_csa
swampfox_csa is offline
Default 4 point docking system in the way
I had a 4 point docking system installed on my 2011 Street Glide and now find the left-side plate blocks access to the rear suspensions' air valve. Is there a tried and true, relatively easy fix for this? I'm pretty sure it will involve relocating the valve... just want to know if someone has done this and what specifically they did to give them access.
Thanks in advance.
Old 04-23-2014, 11:44 AM
Frank Dukes's Avatar
Frank Dukes
Frank Dukes is offline
mine is slightly in the way but you can still get it. its a little easier if you take the bag off to adjust it.
Old 04-23-2014, 12:06 PM
swampfox_csa
Thanks Frank. Must be that our valve stems are at slightly different angles. Mine just won't get past the docking system, bag on or off. I don't have any concerns with having to take the bag off... I just need to be able to hook up to the damn thing.
Old 04-23-2014, 12:10 PM
LS Bob's Avatar
LS Bob
LS Bob is online now
Yeah, I'm thinking yours is bent or twisted somehow, putting that stem at a bad angle. I have the 4 point and have no issues with getting the pump on there.
Old 04-23-2014, 06:56 PM
Dr. Tiki's Avatar
Dr. Tiki
Dr. Tiki is offline
Get JRI shocks.
Old 04-23-2014, 07:23 PM
RollaMo's Avatar
RollaMo
RollaMo is offline
The 4-point docking hardware should in no way interfere with the shock valve stem.
Although I no longer have the air shocks on my Street Glide, when I did there wasn't any issues at all fitting the pump on the air valve.
Old 04-23-2014, 07:32 PM
BigDawgQC's Avatar
BigDawgQC
BigDawgQC is offline
Swing buy a dealer & see if they will adjust it real quick. (yeah, I know...good luck with that)
BaggerAudioLab
Audio Systems
30
04-02-2017 09:30 PM
tlguitar
08-12-2013 02:03 PM
rhd01
05-01-2013 05:07 PM
Smitty79
01-03-2012 02:46 PM
DrPlastic
08-31-2008 09:03 AM
Quick Reply: 4 point docking system in the way
