Picked up a new FLHR, want to adjust the handlebar for optimum wrist angle/comfort. Thankfully, the plastic cover easily pries off to access the two bolts I need to loosen to roll the bar fore or aft.. I don't wanna mangle up the bolts..they look like hex bolts. Anyone know the size and should I use ball HEX ,
allen, or ? Anything I should look out for?
also don't forget that the control/mirror location is going to change in comparison to you hands, and that you can't twist them up or down on the bars like in the old days because they are wired internally in the bars ...
Unless I misunderstand the issue, you can loosen the torx bolts on the controls and rotate them to any position you want. I have.
hmmmm I wonder if this is true.
Originally Posted by sharpshooter
Are they not Torx? My 12 rkc looks to be a T40 Torx..
I looked again and definitely not torx. 1/4 allen it is.
Bob
gonna try this as well. I hope nothing bad happens.
Thank you.
So the chromed cover with the fork lock in the center just pries off? There's no tab to push in, no hidden bolts, etc? I'm wanting to rotate my '14 FLHR bars forward but I don't want to break something on a brand new bike. Where is a good place to pry it off without scratching the upper fork covers?
And what is the torque spec on those rear clamp bolts?
I guess it's time to order a service manual. Thanks in advance.
Reason: Another question
