Compensator Gone
Compensator Gone
Well started having issues starting my 09 Ultra around the end of March. Starter would turn over and then a bang would occur intermittently. Took it the dealer and they were unable to duplicate the problem of course.
Went on for about another month progressively getting worse until it happened almost every time and sometimes started with a backfire. Took it the dealer today and the compensator is toast, which also screwed up the starter clutch. Glad ESP is covering it. The stock compensator has also been superseded by another part number, so I'm assuming this was a known issue.
Anyone notice any extra vibration in the footboards after your comp went bad?
I have a ton of drive line slack and huge vibration around 2200 rpm and idle/start off. Trying to figure out if the comp could be my problem before opening it all up.
Clutch feels good, no vibration there.
lp
lp
Well, talking with the service manager after the work was done, it seems that SE compensators are on back order. The compensator itself was undamaged, the springs were the issue, so they managed to get hold of a spring kit from another dealer. In addition to a spring kit, starter clutch, rotor, and misc., other parts that the compensator spring failure broke I'm back on the road and much improved. Leaving next week on a road trip, so hoping it will hold out at least through the summer.
