cant get ignition lock back in
Well went to change fork oil and could not break free those star fork sliders drain bolts tried everything and they wont move and started to strip so by now i said screw it and went to put everything back together and will try some other time as now the one drain bolt is stripped.Would like to meet the harley engineer that came up with those instead of allen bolt anything is better than star or as we call them phillips.Now problem i cant get ignition lock back in. The forks were locked when i took switch out and now they are not locked.I stuck a screw driver in and can here a click when i turn the screw driver problems is no matter which way i go and how many clicks i go in both directions i cant get the forks to lock postion to get ignition switch back in.Any help would be great as i been trying this for 2 hours already.Need a beer thanks in advance
Well i have watched the video i had the lock in lock position had the key in pressed little tang under lock while turning lock counter clockwise lock came out no problem forks were locked but somehow they ended up unlocking and when i stick screw driver in i can turn and here the click but i cant seem to find lock position to get forks locked so i can stick ignition assembly back in will have try again just dont have it in me now a little pissed
I've been there before. With a screwdriver it does takes some patience as everything needs to line up which can be a pain. Hang in there and come back to it later and you'll get it...
Keep trying use a flash light to see if everything lined up. Turn handle bars to left turn ignition in lock position then try lining up with screw driver or even by inserting the ignition all the way or half way to line it up. you will be surprise when all the sudden everything lines up and you get everything in working order.Walk away then go at it again stay calm don't rush.
