Road king belt adjustment
Old 05-17-2014, 05:57 PM
steve.13's Avatar
steve.13
steve.13 is offline
6th Gear
Default Road king belt adjustment
not how i wanted to spend a Saturday,or any other day for that matter.last week belt popped went today and got belt,couple more trips out for tools i didnt have,,ok i am in the reconstruction stage have swing arm and tire and belt in place and checking..as i rotate tire forward belt travel seems fine but if i spin tire reverse belt rides all the way in on the primary and turning forward does not cause it to ride back out. if i "feed" the belt (screwdriver behind) as i turn forward it stays centered on sprocket ,,till i roll it reverse.and it seems to stay centered on wheel sprocket either way??at $250 plus tax,,i want to make sure this belt is perfect
Old 05-17-2014, 07:09 PM
GTK's Avatar
GTK
GTK is offline
Default Belt adjustment
You have the rear wheel off center causing your problem.Put a little slack in your belt and adjust wheel one side at a time untill condition is better or if unchanged,moved other side back.Once you get belt centered on pully adjust both sides evenly back untill belt has correct play.All belts will ride off center a slight bit when wheel turned in reverse.
Old 05-17-2014, 07:58 PM
Ragtop's Avatar
Ragtop
Ragtop is offline
Received 1,011 Likes on 576 Posts
how much do ride in reverse?
Old 05-17-2014, 10:02 PM
steve.13's Avatar
steve.13
steve.13 is offline
6th Gear
not that i ride in reverse....but i was asking for help with a problem,which i thought the forum was for ,not smart *** answers to add to someones post quanta.the amount i turn the wheel in reverse is less then the revaluations it would make for me to back into a parking space once,, and on a normal day i would probably do twice.so in my book if you cant help,.keep your mouth shut rather than add a notch
Old 05-17-2014, 10:07 PM
steve.13's Avatar
steve.13
steve.13 is offline
6th Gear
thanks,,will try in the morning,did not make sense to me ..why if belt is true and both pulleys are true why would belt run different in reverse?
Old 05-17-2014, 10:29 PM
smithbrl's Avatar
smithbrl
smithbrl is offline
The forum is a great source of information/help as well as entertainment. Take the good with the bad and enjoy it.
Welcome to the forum.
Old 05-17-2014, 11:02 PM
my67pnycar's Avatar
my67pnycar
my67pnycar is offline
Lesson for next time you take the rear wheel off, mark the position of the adjusting cams before you take it apart.
Old 05-18-2014, 12:04 AM
dickey's Avatar
dickey
dickey is offline
Received 5,477 Likes on 2,477 Posts
Hey; Lighten up n the guy, man. This is not your average forum. We mostly have thick skins here, and to hang with us, you gotta develop a thick skin yourself. We goof, we kid around & throw friendly insults at each other. We even occasionally post pics of the craps we take! If you wanna be serious (& bored to death) there are plenty of forums where they will love you, and one where you won't even hear words like gosh or darn! We'll let it slide THIS TIME since you're new hereLOL!
Old 05-18-2014, 05:30 AM
steve.13's Avatar
steve.13
steve.13 is offline
6th Gear
thats the thing,the other belt broke ,so the adjuster cams were never moved.they went back on exactly like they came off.
should the rear of the engine be able to slide back and forth when the swing arm was out,at first could not understand why it would not fit back in,,then i pushed the whole motor over and realized it would slid back and forth
Old 05-18-2014, 06:57 AM
jus2anoyu's Avatar
jus2anoyu
jus2anoyu is offline
Just throwing this out there..... Unless said bike has a ton of miles or picked up some serious debris, I'd be searching for the reason this belt gave up. Or perhaps you are discovering it right now....
Quick Reply: Road king belt adjustment
