Need some extended shifter pegs
After finally adjusting my heel toe shifter (I can finally fit my boot under the shifter peg). I thought the heel shift would grow on me but it didnt. Ive realized I need some extended pegs. What are you guys running? Any pics? I looked at changing the whole thing out but for 350 bucks ive decided against that option for now...
Pingel makes an extender/ spacer. www.pingelonline.com
are you looking to extend your shifter peg to move it out further away from your engine, or are you looking for extended shifter arms to move them forward and back, giving you more room on your floorboards?
if you want to move the shifter out, what i did was to remove both toe and heel shifter levers. put a spacer on the spline, and then put the toe shifter back on. that will move your toe shifter out about 3/4'', and i find that to be plenty.
Softbrake for extensions. ordering a rear to place the heel shifter flush with the floorboard so I can use it to shift and hang my boot off the back as well
http://www.softbrake.com/
Pingel makes an extender/ spacer. www.pingelonlne.com
This link might be better............ http://www.jpcycles.com/pingel/forwa...s-and-footpegs
makes a lot of sense. you would need the spacer to move it out then (assuming you don't mind losing the heel shifter). also, maybe move the lever one tooth on the splined shaft, that'll give you more lift.
http://www.dragspecialties.com/produ...oductId=184781
