Rear brake not working.
Old 05-19-2014, 07:24 PM
WILDWOOD_1124's Avatar
WILDWOOD_1124
WILDWOOD_1124 is offline
Default Rear brake not working.
I'm leaking brake fluid where the switch for the brake light plugs in. Any help appreciated!
Old 05-19-2014, 07:29 PM
wenterkin's Avatar
wenterkin
wenterkin is offline
I'm sure someone with better info will jump in soon, but I seem to remember something about bad brake light switches a couple years ago.
Old 05-19-2014, 08:35 PM
IrishHogtrotter's Avatar
IrishHogtrotter
IrishHogtrotter is offline
As wenterkin said, there was a recall on 09 EGs regarding possible seal failures near the brake switch....check with your dealership if your ride is covered.
Anywho, from you describe, sounds like a seal has popped and needs replaced.
Old 05-19-2014, 09:06 PM
WILDWOOD_1124
I did find a thread about a recall on the switch on 09-11 touring models.
Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Reload this Page
Harley recall brake light switch
Old 05-19-2014, 09:13 PM
EricD10563's Avatar
EricD10563
EricD10563 is offline
Mine went up in smoke on video when I was supposed to be filming my new tail light that I installed on my 09 Road King.
Old 05-19-2014, 10:33 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
so replace it- call the dealer with the VIN, maybe they'll cover it.
if the exhaust is aftermarket you may have a fight on your hands. ( the switch may give up under exposure to high heat- the stock switch could fail when subjected to the heat of a stock exhaust- especially with a catalytic converter)
if ABS the Digital Technician should be plugged in when bleeding. Some guys bleed their ABS bikes at home, but this takes some knowledge.
don't count on having a rear brake when the system is leaking like this
mike
Old 05-20-2014, 04:53 AM
WILDWOOD_1124
Going to the dealer today. Hopefully they have a switch in stock! I'm leaving Saturday for a week trip in the Smokey mountains.
Mr Brown
05-12-2015 07:01 PM
silvertex1
Electrical/Lighting/Alarm
10-22-2014 07:12 AM
CSM Sandoval
12-19-2012 02:56 PM
Benway
12-15-2012 08:53 PM
frenchbiker
10-26-2011 05:25 PM
Quick Reply: Rear brake not working.
