engine pinging
Not to hijack but since we are talking fuel as the result of ping... Ethanol bumps the octane so it that the correct choice High Octane with Ethonol or a lower octane without ethonol...
Also ?? on the low end... when I try to jump back on the gash when in to high of a gear when slowing down I get some ping and clanks etc... it that what you are refering two?
octane rating is octane rating- whether lead, ethanol or whichever additive packages current or past.
wikipedia will be a better source if you want to read up- but octane does not mean "more power" higher octane allows the motor to be tuned for more power- allowing more advanced ignition timing and/ or higher compression ratios than otherwise.
octane is the ability of the fuel to resist combustion from compression ( like a diesel ) and better controlled burn rate in the combustion chamber
mike
mike
Ethanol adds octane and burns cooler....It's not the cause of your detonation. It's warmer out, which means the engine's running hotter. OP's bike is a 2005, and I'd bet he's got some crud in his combustion chambers (as a 9 year old bike will have) that's effectively bumped his compression ratio.
mike
mike
