Shifter Rod Lever loose, won't tighten ?
Re. : 1996 FLHTCI
Not foot shifter or linkage.
Lever that slips over splined trans shaft.
Lever is located between trans and primary.
Foot shifter linkage attaches to this lever.
Lever switches gears in trans.
This lever is totally loose.
Allan bolt is on max tight.
With finger, can slide lever to end of splined shaft,
until it touches primary, lever barely engaging the shaft.
Lever is too thick to slip completely off shaft and remove it.
Seems a hundred years ago had same problem with another bike,
think '92 low rider. Can't remember what the repair was.
Any help?
Any help?
Received 47,744 Likes
As was mentioned earlier, you can ( and I have successfully ) tighten it up. First remove the bolt. Lubricate the old bolt and run it in and out of the lever a couple of times. Discard the old bolt and use a new bolt ( grade 8 might be overkill but acceptable ). Put some Loc-Tite ( Blue ) in it and torque it down. It will tighten up and should resolve your problem unless the shift shaft out of the trans is shot. Hope this helps!
Thank you gentlemen.
Here's what I did in my shop (20 Mins.).
Caveat: Lever not removable on Evos (5spd) unless primary pulled.
Twin cams are different.
Re.: 1996 FLHTCI, 1st Yr. injected.
1. Removed allan bolt.
2. Used cutting wheel on Dremel w/flexible extension.
3. Guided wheel into existing pinch gap on existing lever. Used variable speed to carefully glide wheel back and forth, also, fingers to reposition lever on shaft as needed, to clean out, widen pinch gap nearest the shaft.
4. Squirted with brake cleaner.
5. Hit with air hose.
6. Used same allan bolt.
7. As I tightened bolt, could feel lever compressing, getting a new "pinch".
8. Actually tightened bolt to less than previous unsuccessful whammy torque.
9. Lever is tight--very tight on shaft now.
10. Will replace allan with Grade 8 Hex (5/16 24 x 1???)
Note: There is actually adequate room between the primary and trans to do this. Did not even have to put bike on lift.
Prognosis: Let's see if I can get another 35K miles on it.
Prequel: How I came to this plan.
If bolt is whammy tight onto lever, and if lever not compressing onto shaft, and lever is still floating around loosely on shaft, then, obstruction in pinch gap. Possibly bad original design or manufacture results in pinch gap closing on itself, nearest the shaft. Have seen some of these old bad levers, and it looks that way to me. The pinch gap does not remain parallel, instead, it meets itself at the inner end, closest to the shaft,
while the outer end, farthermost from the shaft is still showing a gap.
Thus, remove material from the pinch gap, closest to the shaft, and the lever should be able to tighten onto the shaft.
Please, hold your applause for the next 35K miles.
PS. I'm going to post this as an independent topic. Might be of help to another Evo guy some day.
