Head temperatures
I see you are pretty new to the forum. There are already many threads discussing this issue, so if you do a search you will more than likely find way more info than you actually want. There is really no set answer to this question as it has much to do with whether your bike is stock or modified, how it is modified, and whether you are using any cooling devices such as fans and oil coolers. My bike in the situation you mentioned will run about 270 degrees F. I have a good oil cooler and FSC fans, but they are the early models and they lose effectiveness above 50 mph. The bike actually has lower head temps at lower speeds. Your bike may see higher temps in the same situation or it could be lower.
When it's 85 degrees I run about 240 - 250 at a steady highway speed (60-70mph) depending on driving style. That's according to the PowerVision listening to the ET (Engine Temp) channel from the ECM. Not sure if that's technically "head temp".
I have an aftermarket intake, PowerVision, stock head pipe and after market mufflers. I do not have data from before my bike was modified.
He joined a month before you.
Too many variables to say xxx is a "normal" temp. Ambient temp has minimal impact on CHTs, RPM and vehicle speed are the biggest contributors affecting CHTs. Modifications and operating conditions make it very challenging to establish "normal"
http://www.wardspartswerks.com/new-p...ance-data.html . The last chart is a 70 MPH run at about 82-85F ambient, 06 SG 88", 5 SPD, stock type tune, one set of traces is without fan. Most folks have no visibility of CHT or ET, but those who do are usually limited to the front because that's where the OEM ET sensor is and that's what the aftermarket tuners read. In non-extreme conditions, 260-280 CHT at traveling speed is not uncommon.
And the altitude you are running at will also have an effect on the CHT. The higher you go, the warmer your bike will run.
Generally speaking, when cruising down the road, anything below 280-300 is just fine. If sitting in traffic, it really doesn't matter. When I called MoCo because I was curious if they recommend shutting it off in traffic, the guy I talked with said that they have a test track in AZ and in the middle of summer will run bikes hard and let them idle for hours on end and don't have any issues. His commetn was "if Harley thought that the bike could reach a temp that was dangerous, the ecm would be set up to shut it down or put it in limp mode and then shut it down." and he's unaware of any setting that does this.
I was on vacation when Gaugeface issued an update for the app, I updated it and forgot about it. When I finally went for a ride, I noticed it was almost a hundred degrees off and I contacted them and they reminded me of the update. They found out apparently that the Gaugeface was calculating the signal from the ECM wrong. So all of my base temperatures that I knew since the bike was new, have now gone out the window, and I have to start all over again. I just installed Gaugeface on my buddies 07 HD and we compared the numbers on his first run, which seemed to run the same within a couple of degrees.
BTW, I never saw my head temp over 210 degree's with the older Gaugeface version.
Brion B
10-08-2012 10:06 AM
johnnyshrooms
11-03-2008 11:19 AM
