Oil coming thru Schrader valve on shocks?
06-30-2014, 01:20 PM
On my 04 Ultra, I went to release the air out of the rear shocks and it looked like it spewed out oil on my finger, could it just be moisture built up? Time for a re-build?
06-30-2014, 01:23 PM
Yes they build pressure. Usually if possible try to add a couple of pounds of air then check the pressure and set to amount wanted.
06-30-2014, 01:32 PM
Owners manual says to add a little air before releasing pressure to blow oil away from valve.
06-30-2014, 01:47 PM
Location: Western Illinois, land of bad roads, and corrupt politicians
Quote:
Originally Posted by
Greg2012FLHTK
Yeah that........ if you can't find it, your manual is probably under the leg of the kitchen table that used to wobble.
06-30-2014, 03:41 PM
I usually put it under the jiffy stand
TwoBlue02
06-22-2015 11:08 AM
chevdude
05-04-2015 10:54 AM
LateBloomer
09-29-2013 11:42 AM
Horsetrader
Air Suspensions
10-13-2011 07:15 PM
webehere43
07-28-2011 11:37 AM
