Road King Windshield Bushings and Studs
You know, sometimes it's the damnedest things that bug me that I need to fix. This time it's the half assed RK windshield mounts. So tonight I decide to do a little experiment and remove the fangs in the hot weather to see if there's any improvement with more air flow in the heat coming off the back pipe under my right thigh. Not loving that.
So the simple plan is pop off the acorn nuts, remove the deflectors and reinstall the acorn nuts. Ten minutes max, recall thinking less than five. But, as was the case when I installed in three out of the four studs the entire stud comes out. And with that the black bushings are falling off, etc. etc.
I then hatch a plan to red Loctite the studs in so they don't so easily come out in the future. Easy enough except I have to get the acorn but off the stud first. So after futzing with two nuts tightened together on the other side they are all off. Then, using the same method I installed them back into the holes. But it took some trial and error to get the depth right. I thought they would seat themselves. Not so much but they are in. We will see how that works out in the future.
But the real point of all this that I am finally getting to is how crappy the black bushings perform with everything tightened down. They deform and the shield is then so damned difficult to install. And do those silly 'locking' thumb wires actually do anything but get in the way? Or have you taken them off?
Am I doing something wrong here like over tightening the nuts? Seems like they oughtta be pretty snug for what they're holding on. Has anyone installed a metal spacer in the bushing hole to create a positive surface to tighten against while not deforming the black rubber mounting bushing?
In a perfect world, those springs sit positioned to hold the windshield against being pulled forward. You would need to lift them in order to get the windshield off. In a perfect world.
Mine habitually sit high, doing nothing for security. They do provide an entertaining buzz as they vibrate wildly at certain road speeds or engine rpms.
My springs are apparently made from a mild steel, not a spring steel. They bend easily and don't retain their shape worth a darn. It means every time I reshape or reposition them to actually work, they promptly get bent into a non-working shape.
Why we get blessed with this poor design, while the soft tail mounts use a far more effective design, I've no idea.
When I added the fangs to my bike, all 4 bolts came off with the acorn nut. on the first one, I was like what the hell so I tried another. When it came off with it I figured this must be how it is and the MOCO used acorn headed bolts instead of what I had assumed was a fully threaded piece and took all 4 off. They all came out completely, and of course a couple of the black bushings dropped and rolled on the ground.
Next time I have that loose, I will use a couple nuts and separate them as you did.
As for the springs, they don't do anything other than ride high to no effect as far as I can see.
springs
Not sure if my RKC shield springs are more flimsy or not- pseudo functional at best it seems on them too.
