Idling Problems
07-05-2014, 08:00 AM
Idling Problems
I ride a 2009 Ultra and am having problems with my Idle. Bike wants to idle at just over 2000 RPM, if I roll the throttle forward it will decrease but it idles back up when I release the throttle. Has any one had anything like this?
07-05-2014, 08:10 AM
Sounds like the grip is to too tight. There needs to be a little back and forth movement.
07-05-2014, 08:25 AM
cycle ignition switch on/off 4 times with Stop.Run switch set to Run.
On - count 1,2,3
Off - Count 1,2,3
repeat 3 more times.
by the way, this happens when you shut off the bike with rpm above idle. ECM sometimes remembers the rpm as the "new idle".
07-05-2014, 09:36 AM
yeah, I have to remember to use my right hand to turn off the ignition switch when shutting down.
the old habit of using my kill switch will often require a throttle reset as outlined above
mike
07-05-2014, 11:57 AM
Thanks guys I do have a habit of using the kill switch.
07-05-2014, 01:15 PM
Thanks. Had the same problem yesterday myself.
hotwires
08-22-2018 01:41 AM
nicmartim
07-07-2018 05:47 AM
Afdharley
Screamin Eagle CVO Models
04-03-2015 09:25 AM
Larry9901
07-15-2014 12:08 PM
Drtbag
09-03-2008 01:01 PM
