Front brake seems to stop working when I hit a bump?
Let me try and describe the feeling in the brake lever a little better. When it happens it feels like you lose brake pressure and the front lever has less resistance and you have to squeeze it more to get the "feel" back in the lever. Its a very strange sensation. If you have ever bled brakes in a car it feels like when you buddy releases the drain and the pedal sinks towards the floor in your car.
Have you ever been in a car in an abs mode? The pedal feeling does change because the system is taking over to try to bring a vehicle to a controlled stop. Thats why if you release the brakes the abs mode is cancelled and reinitiated when you apply again. Thats why its imperative to stay on the brake a d not release it. I cant speak for the new HD abs but what I described is typical for antilock brakes. If you honestly feel there is something wrong and it was not an operator error ina s braking procedure by all means take it to a qualified shop. Brakes are nothing to cheat on.
Your bike has ABS.
You described an ABS event.
Never let go of the brake lever or pedal during an ABS event.
Or
Let some of these guys who also don't know how ABS works or what it feels like when it engages talk you into believing something is wrong with your bike.
I can't understand why someone who bought a bike with ABS wouldn't go to a wide opn parking lot or deserted road and get a feel for the ABS engagement.
THEN, practice making quick stops without having the ABS activate (threshold braking).
Or
Your bike has ABS.
Or
Or
I have ABS in nearly everything I own. When I have an "ABS event" in one of my cars or trucks the pedal does not release and go to the floor or anything.
What I feel is a vibration as it pulses and as soon as the event is over, the pedal is at the same place it was when I first pushed it. Crazy right?
The two Harley ABS bikes I've owned... the pedal goes down dramatically on the rear during an event and you basically have to let up on the pedal to reset.
I'm talking like it feels you have no rear brake at all and to further brake (because you're still braking) you have to push even further down on the pedal beyond where you pushed originally - it's a strange feeling I learned to live with.
Fronts.. not so much but the lever does sink a wee bit.
So I can understand how someone would feel like it's a loss of brake after hitting a bump. Happens to me all the time. Especially the rear.
lp
lp
Okay dump valve huh? Did it again today over some pot holes and took the brilliant advice and did not let off. That was a fricking mistake as I had no front brake until I let off and reapplied the brake and damn ran a stop sign. Super scary and there is some kind of issue with the bike's ABS.
Taking it in to the dealer and let them clean their drawers when the brakes stop working.
I think you have the "why" figured out. They all do that. Several quick "bumps" seem to trigger an ABS event if you're coming in "hot" and on the brakes aggressively, especially the rear. If you keep hitting potholes and bumpy pavement in areas where you will need to use your brakes you might try slowing down a little sooner. This will give you more stopping time and probably alleviate you situation.
The brilliant advise you got was just that, brilliant, for a normally working ABS system. I don't see too many ABS problems here but that doesn't mean you don't have one. Does the yellow ABS light come on when this problem occurs? Hopefully, since you're taking it to the dealer, they'll get you fixed up.
I've had the same problem and it's scary crossing that white line and finally stopping in the intersection. It only took me one time to realize what happened and to start stopping sooner in those situations. My problem was that I was not familiar with ABS brakes on a Harley Davidson. From what I read here, BMWs have better ABS systems but I have never ridden one.
This is a good opportunity to remind everyone to leave plenty of space between you and the car ahead of you in case he stops quickly on a bumpy road surface. I keep telling myself to do this but it doesn't always happen.
