Front brake seems to stop working when I hit a bump?
Okay dump valve huh? Did it again today over some pot holes and took the brilliant advice and did not let off. That was a fricking mistake as I had no front brake until I let off and reapplied the brake and damn ran a stop sign. Super scary and there is some kind of issue with the bike's ABS.
Taking it in to the dealer and let them clean their drawers when the brakes stop working.
I will take that bet. Damn near rear ended a car today after a man hole and small pot hole right after each other triggered the ABS to "freeze up" my front brake again. Squeezed hard and did not release as recommended for ABS and nothing. Let off and reapplied and they started working but I had to pump a little and braked hard and the worked. Something aint right!
Man, I guess I can learn to not brake over bumps or anything but you should not have to think of when to brake. My warranty is up in Oct so I will get it checked but if that is factory operation then for lack of better words it sucks!! I really want ABS but this crap can be scary.
Are you using both front and rear Brakes to their fullest potential? I bet a lot of people don't use half of it. Practice it will save your life.
I'm confused.... I just got my first abs bike and I don't seem to be having any of those problems or feelings with mine. It was so easy to get used to, and I really can only say that I've felt the abs come on two times. Both times was me trying them out and slamming on the brakes. I can imagine that would be a bad feeling having your brakes go soft like that. I ride on some really rough roads and have never once felt the abs come on. I actually find the opposite when I'm stopping. If I come on to the front brake, I feel the pressure INCREASE in the rear. I assume that's the linked brakes working.
Anyways, I'm sure you guys all know more about them than me, but if my bike started acting like that I would have it looked at too.
