Best way to wake up my Rinehart 4"?
Right now I'm running stock head pipes/AC with only Rinehart 4" slip-ons with their standard baffles on my '14 SGS. I'm happy with the tone but not so happy with the volume (or lack thereof). I was thinking of adding some V&H Dresser Dual head pipes to add some more volume and while I was at it, throw on a new less restrictive AC and retune (PV).
I got to thinking. A few years back I had a Fat Bob with VH pipes that I added Big City Thunder baffles to and wow what a difference it made.
Just curious what everyone thinks would be the best way (and possibly the easiest/cheapest way) to achieve my overall goal of more volume. I'm satisfied performance-wise with how the bike is running now, so if I were to do the full Stage 1, really it'd only be to get more volume. Seems kind of silly to sink all that money into it if I don't have to.
Thanks for your thoughts.
Well it sounds like you did what I did and just threw the slip ons on. I just installed a set of RC X components rival mufflers and they are louder then stock but have a very deep tone tho and seem quite compared to when I threw a set of slip ons on my Fatboy! I was told with the Touring Harleys removing the cat helps to make it loud. But once you do that then you have to tune.
http://rinehartracing.com/accessories/baffles/100-0111
They are a larger diameter, and somewhat louder.
Back when Rinehart was my exhaust of choice (I've grown up since then) I recall that they got significantly louder after being used for a few thousand miles. I assume they have some sort of packing around the baffles, and as that stuff "burns in" the volume level does increase noticeably.
If you leave the air cleaner stock, you likely won't need a new tune simply because you remove the cat or move to a new head pipe (retaining closed loop of course). Most go full-out Stage I and be done with it. You won't be happy until you do because you will always be wondering..."how much better can I make this thing with a Stage I?".
However if you are worried about warranty issues, I suggest you just fiddle with the exhausts for now.
Stage I and de-cat the head pipes (engine runs cooler). will wake them up a lot. Mileage also increases their deep throaty sound. I love it!! After that put on the NiteRider FL-Vied-10 to tune the closed loop. Makes all the difference in the world. Smooths out the throttle, brings back 40+ MPGs and runs cooler even more.
