1994 Electra Glide Rear Suspension
Old 07-15-2014, 07:19 PM
CarCycle's Avatar
CarCycle
CarCycle is offline
1st Gear
Default 1994 Electra Glide Rear Suspension
G'day all,
Im writing from Adelaide, South Australia.
I have just purchased a 1994 Harley Davidson Electra Glide Ultra Classic... not knowing much about these models (have a 10 soft tail) I thought id ask my questions here!!
I purchased it from a salvage auction and it needs a new rear rim...
Will a 1997 Road King Rim fit? It appears to be the same pattern etc...
Also, the rear end is on the ground... the shockers/suspension is fully compressed is this an issue or something that will rectify itself when it going?
Many Thanks
Alex.
Old 07-15-2014, 07:44 PM
CarCycle's Avatar
CarCycle
CarCycle is offline
1st Gear
Any help would be greatly appreciated!
Old 07-15-2014, 07:50 PM
dawg's Avatar
dawg
dawg is offline
Received 2,938 Likes on 1,701 Posts
The wheel will fit, both years used same wheel. I'd pull the shocks, test and replace if needed. Shouldn't be "on the ground."
Old 07-16-2014, 02:39 AM
CarCycle's Avatar
CarCycle
CarCycle is offline
1st Gear
Thanks for the info regarding the wheel, will be picking up the replacement shortly!
Yeah with the rear shocks they are completely compressed!? whether this has happened due to accident damage or they leak or something I don't know as I am not at all familiar with them.
I've attached a photo of it showing how low it is sitting!
Cheers
Old 07-16-2014, 02:50 PM
Mathnerd's Avatar
Mathnerd
Mathnerd is offline
From your photo it looks like something is broken/missing.
The shocks are one possibility. Is the existing wheel damaged to the point where it could be causing the issue? Take a bag off and take another photo if you can so we can see the rear suspension.
Old 07-16-2014, 04:59 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Hi from the UK and welcome to the wonderful world of HDF and Evos! We have a dedicated Evo forum for your future reference. The other wheel will be fine. As for why your bike is on its knees, you need to start taking stuff off, so we can all see what is going on, as Mathnerd points out.
Old 07-16-2014, 05:47 PM
Def Mute's Avatar
Def Mute
Def Mute is offline
I'd be surprised if compressed shocks would dump the ***-end that low...
Wonder if it has air ride installed? Gotta take the bags off to check it out. Anxiously waiting to see whats under there...
Old 07-16-2014, 07:24 PM
dawg's Avatar
dawg
dawg is offline
Looks like flat tire or no tire at all causing that.
Old 07-16-2014, 09:27 PM
CarCycle's Avatar
CarCycle
CarCycle is offline
1st Gear
Thanks guys, as mentioned the shocks are fully compressed... Plus the tyre is flat!
Wheel is being replaced today so it can be moved around a little easier!! Then the suspension will be looked at!?
It's like they're locked on? They are air...
Old 07-17-2014, 03:43 AM
grbrown's Avatar
grbrown
grbrown is offline
The angle of the swingarm indicates that the collapsed height of the shocks is shorter than stock, to my eye. Stock shocks when full compression are just over ten inches long IIRC, so let us know what those measure up at. It is possible they are aftermarket air shocks (non-stock). They will have some means of pumping them up (if they still work!) or there may be an electric pump on the bike somewhere, to do that. If you can't quickly solve that puzzle, either find a pair of secondhand shocks, or dump the ones on there and get some decent new ones.
Quick Reply: 1994 Electra Glide Rear Suspension
