Shock Oil Change
That's awesome! I want to swap my oil out too on my 12" Road King Custom shocks and was going to use my hitch on my Silverado and jack trick. I'm about your size so I'm looking for a smoother ride. I think it rides good now but feel there is room for improvement.
Anyone know how much oil the 12" shocks need?
I've heard all sorts of ways to do this and many different contraptions to accomplish the task but this is about the simplest and best idea I've seen. Might be better with a length of hose attached though to cut down on the mess.
I just read an article( made copy) do not remember from where ( Senior moments I quest) and he used the Harley air pump or an aftermarket version to place pressure(40-50#) on the shocks so when he pulled the air line this let the fluid come out in a controlled way. He was able to measure the old oil so to be sure to replace the same amount. The article stated that both shocks had to be taken off and re-plumb on the bench as if they were on the Bike so to keep the air system closed. I know not very well explained but I have not used this method yet but will. I have the instructions at home if anyone is interested and can not find the site ride safe.
