Need help
Set the time-of-day with the ignition/headlamp key switch turned to IGNITION or ACCESS but with the stereo receiver OFF.
Press the Set soft key (6) (Set) on the front panel to display the time setup menu.
See A in LCD Display Examples. To increase the hours in the display press the Hrs+ soft key. To decrease hours press the Hrs- soft key. When the hour is correct, release the soft key.
To increase the minutes in the display press the Min+ soft key. To decrease minutes press the Min- soft key. When the minute is correct, release the soft key.
