Not enough oil
07-24-2014, 09:41 AM
Quote:
Originally Posted by
SmokeyJoe101
Opened her up and added about 3 more ounces to bring it up to par. Changed the gasket to boot.
Why change the gasket?? I have the orig gasket, no leaks have open and close the primary 6 to 8 times........
07-24-2014, 10:00 AM
I have an RSD clarity cover and it uses a different gasket.
So the dealer called me and said my hydraulic clutch master cylinder was shot.
07-24-2014, 11:14 AM
turnerbend
If you`re careful I see no reason to change that gasket.
07-24-2014, 12:50 PM
Well the one time I tried to reuse the gasket it leaked. So from the guy who asked it 35 ounce of oil is enough, I play it safe with my gaskets....
07-24-2014, 01:17 PM
SmokeyJoe101
Smart man, why take the chance. For me if $hit can go wrong it certainly will. I take no chances either.
07-24-2014, 02:23 PM
KCFLHRC
I wrench for a living, I see no value in " Oh, it will be ok" Always use a new seal.
07-24-2014, 05:09 PM
sixguns
Just a tip from one "wrench" to another:
If the gasket surface of your inner and outer primaries are clean and dry you can put a very light coat of clear RTV on both sides of the gasket and re-use it several times - those things are $30 each.
The derby cover gasket can be used over as well.
07-25-2014, 02:56 AM
SmokeyJoe101
So today I changed the Primary oil and for the life of me I don't know how I did not buy enough oil, but I did not. I had one quart and about 2 or 3 ounces on top of that. The book calls for 38
Do you think it's worth it to open it back up and add the rest?
Follow the check procedure in the owners manual, if it's low, add more!
SpringerRider
13
08-18-2018 02:19 AM
hdchaplain
04-25-2015 09:56 AM
DanMan1
Shovelhead
12-26-2013 10:58 PM
HMZHD41
EVO
11
10-18-2013 03:06 PM
emperor wurm
12-05-2011 01:56 PM
