Apes on Ultra Limited - How high?
How high can I go on my 2010 limited without having to change the brake lines? I don't mind all the other crap, including possibly having to lengthen the clutch cable and other stuff including the TBW cable, but I hate cracking open the front brake system if I don't have to. But on the other hand, if I need to do it I will and figure out how to get the air out some way.
I am a closet ape appreciator. I've always liked apes, but never had a set. I think it's time to pull the trigger. I have read where ape owners wish, after the install, they had gone a little higher. Is this usually the case?
So what can you ape dudes tell me to get me all jacked-up over apes? I know they are cool and comfortable, so I get that all the way.
All my wiring is inside the bars, so I will need a fat-*** bar to get it all back in there I am sure.
For those of you that have done it and respond, thanks a million for all your tips and tricks to get it done without screwing up the farm!
I put the wild ones 14". Can't remember the model number. I went with 14's cause I was shopping 12's. Now I wish I had 16's for a little more pull back. I do like them though and do not plan on switching them for now. I didn't think the brake lines were all that bad. I was just real careful to not disturb the brake fluid manifold once I removed the banjos and then back filled the line from the bleed fitting up front using a special bleeding tool.
Here's my setup right now. These are the HD easy reach bars which did require new brake lines and clutch line. I think I can get about 2 more inches out of the brake line as it is.
If I need more, can you get an extension for the Diamondback Brake lines or do you have to go back with a whole new front brake line? Doesn't matter, just need to know. Thanks
