My factory brake rotors have directional arrows on them. I have no idea how important that is but I figure they are on there for a reason so just turning the wheel around may not be such a good idea either. For the work of dismounting and reversing the tire on the rim, may as well mount a new tire. If you have ABS reversing the wheel would put the bearing rigged for the sensor on the wrong side also.
If you are going to reverse the wheel, remove the brake rotors and turn them around.
The point about tire plys wearing in one direction based on acceleration of the rear wheel brings the question of, what happens when ya use the rear wheel to brake?
the majority of forces on the rear tire are from acceleration. Braking very little. when cruising at constant speed, just to be able to hold the speed is putting rotational force on the tire. that is one reason why a rear wears in half the time as the front. the front tire is basically freewheeling unless the brakes are applied ....
