front brake pads dragging...
My front calipers are dragging!
ch-ch-ch-ch noise of the pads on the rotors.
I had installed new pads, and caliper pistons slid in nicely when I changed them.
09 ABS FLHTP
About 500 miles on the new front pads and I do abuse them, but there is noticeable wear on the inner pads already.
Anyone else have this problem?
09 ABS FLHTP
maybe a couple....had it on the stand last night...tried to listen if it was only one side, seems they both do it...took off one caliper to determine that.
Only thing is how the pads are wearing could be an issue. What kind of pads? How hot are the rotors getting after a decent ride? Also since your bike is an 09 have you ever flushed / changed the fluid?
Thanks, I'll report back.
Received 8,248 Likes
understand that there will always be an amount of pressure from the pads "rubbing" on the rotors. Disc brakes do not have a mechanism to pull the pads away from the rotor so there is not contact. The rubber seals do allow the pads to retract enough there is not a locked or high pressure issue. You will always have brake drag. If your wheel rotates a couple times that is good. If you have brake lining on the pads and there is no metal to metal rubbing, that's good. Also remember the pad material is not that thick on bike pads, so if it looks thin, it actually may still have a lot of useful wear.
do not mistake a little noise in the brakes as a sign of urgent repair!!!
Since you've stated you can free spin it several revolutions and you've ridden 500 hard miles, it's probably normal.
Disc brakes are designed to lightly rest on the rotor. It is only an issue if they are resting with too much force. This would be evident by not being able to free spin the wheel a few revolutions while off the ground or by the rotors leaving blue streaks (getting too hot).
