Checking Tire Pressure on 2014 Ultra Limited
I bought the combination psi gauge/tread depth gauge from HD. The head is 90°
I do not remove my bags to check, but I do have an Atlas 1500 lift in the garage, and I park on it. It is simple to raise the bike up, but the blackjack under it to get the rear tire off the ground and spin it.
Yes, it is a PITA... but it beats the lay on the ground, get off the ground, roll the bike, lay back on the ground, get back up and move the bike again method.
Received 2,523 Likes
I like to check tire pressure when the bike is up on my lift. However that has been broke for the season so I have to lay on the floor and then use the new HD gauge and hose combo I just bought. I have a Pitbull lift on order but don't expect to see it for a couple of weeks. Can't wait to receive it so the wash jobs and other uses become easier once again.
Received 4,281 Likes
I use the 90 degree combination air and tire depth gage as well.
As stated by others, it is really a pain, but not much different from front to back tire.
Then, one day I was asked to check the air on my son's 2004 Kawasaki Mean Streak. Lo and behold, they have a chrome plated 90 degree tire stem. Easiest to check and even the newer straight tire hoses at filling stations work easily.
I sure do wish that HD would add this type of stem.
Well, I have a Pitbull lift but I'm sure not lifting my bike to check tire pressure - you can't lift it in the parking lot of the TownePlace Suites. I don't pull the saddlebag either. I lay on the floor/ground; check the valve location, if necessary move the bike 1 direction or another to get the valve close to between a 5:00 to 7:00 position (approximately), check tire pressure with an offset, digital tire gauge (ROADGEAR brand, it must be 15 years old), adjust if necessary & check again, repeat as necessary until inflated properly & move on. Not too bad, but not a job to do wearing your off-white Dockers & light colored, John Hancock shirt. (Hey, I'm not poking fun - I work in an office with a dress code & my riding clothes don't comply!)
