is dot 3 and 4 same as dot 4 hd
DOT 4 and DOT 3 are chemically compatible. The difference is DOT 4 has a higher boiling point. So if your bike calls for DOT 4 I'd stick with it. DOT 3 will work but you'd be backing up with respect to the fluids capability. Make sense?
Received 1,503 Likes
Location: somewhere in "The Peoples' Republic of Illinois
1 Post
41 + years working on bikes is my qualifing experiance!
Best to not mix any of the DOT fluids. When a label claims to be good for different DOT systems it does not necessarily mean to mix it. DOT 5 is a silicone based fluid and can be use in a freshly rebuilt and clean dry DOT 3 or 4 system. But DOT 3 and 4 are petroleum based and can't be used in a DOT 5 because the rubber won't hold up to the fluid base.
I would avoid mixing the DOT 3 & 4 in the same system. May not be a problem but what is your life worth to you? Why take a chance? Don't mix fluids!
Flush thoroughly with denatured alcohol and dry before using a different fluid.
Only intelligent info on this post, personally I would change the seals and possibly the rubber hoses before doing this!
BTW, never use Dot 5 on an abs system.
