Leaking oil from Inner Primary
I noticed some oil on my garage floor today after a ride it seems like I have a oil leak coming from my inner primary by the Crankshaft gasket. I thinking of doing this job myself but have never taken a primary apart...Is this a easy job or should I let the dealer handle it and if I do how many hours labor will the dealer charge any advise would be helpful Thanks Joe
first find the source of the seep- spray the suspect area with drugstore foot powder ( 99¢ store), the powder will wash away at the source
oil from anywhere will make it's way to the lowest point of the bike...the primary case when on the stand.
if you are sure this is an easy job- but you would be stoopid to do this without the manual.
the clutchhub nut is left hand thread on many models, don't use air impact tools on this or the comp sprocket nut
mike
mike
Wondering where your leak is...
seeing as how none of the bikes you have listed under your post has a 'crank shaft gasket'. They all have o-rings. The primary cover has a gasket. Maybe if you posted a pic of the engine where you believe the leak to be, would be a big help.
As far as taking the primary apart, that isn't too difficult. Although, I would suggest you purchase a service manual to help you through it. Even if you decide to let a shop do the work, it will teach you more than you ever thought you wanted to know about your bike.
More than likely it is the seal on the mainshaft into the inner primary housing. Could be the starter jackshaft seal, or, the transmission mainshaft seal. I run gear oil in my trans so I know by smell if I have a trans leak. I currently have a inner primary mainshaft seal leak. Basic mechanical skills, a service manual and the ability to follow it and some special tools and the job is not too hard.
Neil
RDMC
Neil
RDMC
I took a closer look at the engine and primary its clean and dry except in the one spot I'm pretty sure now its coming from around the wires that come out of the primary which seems to be a common problem ( I did a search) and the proper repair is to change the stator and grommet which seems like a big job I do have a manual but not sure if its enough to get me through this job...
stator wires...some use silicone to seal
a syringe can be used to get the sealant inside the joint ( large bore needle- such as used for woodworking- injecting glue)
just live with it until you have a problem which requires pulling the primary- you can reseal the stator plug at that time
mike
mike
Ok so the leak is definitely coming from the grommet around the stator wires. I decide I'm going to replace the stator and grommet. I have watched some videos and read through the manual ...I spoke to my dealer and they told me they would do the job for 500.00 and replace all the seals and gaskets in and around the primary. What do you think. I'm figuring parts alone have to be close to 300.00 Joe
Neil
RDMC
Neil
RDMC
Rarely is this actually the primary. Had this on two different bikes and it was the same thing on both.
