Larger front tire handle better?
Old 08-12-2014, 06:51 PM
skypilot_one's Avatar
skypilot_one
skypilot_one is offline
Default Larger front tire handle better?
Does a larger diameter front tire handle better? I have a 16" American Elite now, would a 18" or 19" handle better?
Old 08-12-2014, 07:13 PM
Roger That's Avatar
Roger That
Roger That is offline
I don't know about a 16", but I had a 18" front tire on my '12 SG and recently traded for a '14 SGS with the low profile 19". Huge difference in handling. Carves the road much tighter with more confidence. Less sidewall flex. Maybe not such a good thing for me as I already ride a bit aggressive.
With the 18" on the '12 SG, you did not want to use the front brakes in coming to a stop or low speed. Really hard to keep the bike upright. With the 19" low profile, I can easily come to a stop using only the front brakes with the front wheel turned. Feels a lot lighter! Not really sure if it has lightened up the front end much, but it sure does feel that way. The only downside if anything is that you can certainly feel every bump in the road up front.
Old 08-12-2014, 07:22 PM
Keithhu's Avatar
Keithhu
Keithhu is offline
Received 5,364 Likes on 2,619 Posts
I would think that a lot of the improvement you describe would be attributable to the new larger forks on the 14's no?
Old 08-12-2014, 07:24 PM
skypilot_one
I think your handling has more to do with the new front forks. A much better design.
Old 08-12-2014, 07:39 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
The 16" front HD touring tire is within a .10" in diameter of both the 18" and 19" tires on the HD tourers. Less than .05" of a difference in radius. Less tire more wheel should always handle better and ride firmer.
Old 08-12-2014, 08:36 PM
wrenchguy24's Avatar
wrenchguy24
wrenchguy24 is offline
Co worker of mine has a 2010 road king
went from stock 16 on front to 21 inch
He said he see no difference at all in ride or handling
Old 08-12-2014, 08:42 PM
fastbydrmike's Avatar
fastbydrmike
fastbydrmike is offline
Handling is based on the rake. That is why sport bikes handle and turn quickly and allow you to not loose the front while turning quickly on the brakes. I can't imagine going from stock to a 21 inch front wheel that you would be able to turn better especially with any confidence in the front end.
Old 08-12-2014, 08:44 PM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
The '14 has stiffer forks and much better trees, thus better handling. While lower profile 17/18/19 combos will firm up the handling somewhat, the improvement wouldn't be worth the investment. They are for looks. 21" up will mess with handling.
ericl's Avatar
ericl
ericl is offline
I'm riding a 21" on my Road King, dropped the front to maintain center of gravity. Can't say it rides better, but it does ride different, and it was immediate. That was 25,000 miles ago.
Old 08-12-2014, 09:06 PM
jefla's Avatar
jefla
jefla is offline
I don't know for sure.
I look to the racing scene for answers to stuff like this, and all racers/sportbikes use small diameter wheels with a good bit of sidewall. Racers don't use low profile, although I think sidewalls are shrinking. Also, I want tires and wheels that roll through/over whatever my sometimes mixed up heads gets into. So, given rubber selection options, I think 16 & 18 or 18 & 18 with potholes-at-speed level sidewalls are the ticket
Quick Reply: Larger front tire handle better?
