The ordering process has begun for my road glide conversion!
#61
Okay, I gathered up the list of the rest of the parts I need and have them sitting in my shopping cart on the kutter site. Just need to wait until 1 last eBay auction is over to see if I am the high bidder.
I have yet another question, does the outer have the brass threads in the to attach the inner to, or will I need anything special there? Since I got an aftermarket fairing, my guess is they won't be in there. If that is how they attach, if someone know the part # for those I will add them to my order.
#63
I got my Inner and outer today, I was pretty surprised it's here already, It wasn't supposed to get here until the 10th.
Looks really good, and I have no issues with the quality. I did get my order placed with Kutter, and the left turn signal bracket is on backorder. Out of 28 items ordered, only 1 thing, I guess thats not too bad. I tried to call them today to see if they can short ship my order, but the guy there had a message that he was on vacation. I guess I will call on Tuesday. - Does anybody know hoe Kutter handles a back order? just wondering if they will hold up everything else or if they will ship what they have and will send the backorder item when it comes in.
I ended up ordering the fairing gaskets, and the new aftermarket fairing came with them, so I may ask them to pull those off the order.
#64
#65
I think you should still use your idea. If there were 15 of those sitting there, I think it would be a different story. I personally have only seen one with the original scheme in person and I go to bike nights and rallies all the time. Stick with your gut, it'll look bad a$$!
#66
#67
Thank you for letting me know, this was my only concern..
#68
My suggestion when you extend the harness insert the extension wires as far from the speedo and tach plugs as possible as the area where they need to plug in is tight. I also staggered where the wire cuts were so the harness did not have all the cut and soldered wires at the same place. Last i used marine grade heat shrink tubing to seal off the splices. The marine grade heat shrink has glue inside that make the connections somewhat water proof. I have had zero problems over 3 years of heavy use.
#69
