Jingling noise driving me nuts....help?
I had a squeak that was killing me...sounded like a ragedy child's tricycle squeaking. Checked all the heat shields and nothing..tightened every nut I could find.....then one day, I wiggled the exhaust bracket that's under the bike...think it screws into the back of the transmission----it had come lose. May not be ur problem, but just one more thing to check
UPDATE!
Guys, I've stripped down everything in the top end, hammered all fittings and still no luck finding out what the heck is causing this. I'm getting crazier by the day Searching the net, theres lots of rattles and noises, but this youtube link from another rider some years ago is EXACTLY the noise mine is making....about 10 secs in. I don't think he ever got the cause of it, but someone out there must have a clue?
Any help appreciated.
[QUOTE=IrishHogtrotter;13173155]UPDATE!
That was pinging, the video even says that. If you have pinging, and many bikes do, you need to reduce the timing in that rpm range. If it's too lean it can also cause that, but my bet is on timing. Mine has done it since it was new and I've had to take out as much as 15 degrees from some cells to eliminate it. Nothing else worked. Now how you are going to go about fixing it is another issue that I don't feel like getting into now, there are so many choices.
Further update:.....
After mechanicalman's comments, I got to thinking.....and disconnected the fuelpak and ran the OE ECU.
Hey presto! instant improvement! Not 100%, but 99% better as far as I can tell.
I'm putting it down to a) bad map or needs updating or b) faulty fuelpak.
I have contacted Fuelpak and will update the thread with results. So glad it's not mechanical and that damn rattle has stopped .....for now at least.
Thanks to all that contributed thoughts etc, it all helped
