Jingling noise driving me nuts....help?
Old 08-17-2014, 03:05 PM
IrishHogtrotter's Avatar
IrishHogtrotter
IrishHogtrotter is offline
Default Jingling noise driving me nuts....help?
I get a noise like stones hitting mudguard from the top end of my 09 EG classic. It's not pinking, codes show I'm actually running rich...I checked my heat shields, tightened exhaust bolts and checked every hanger I can think of. It happens when the throttle is rolled off, or when coasting, not when under power.
I stripped off the slip ons to check baffles were tight....Its driving me NUTS.
LOL! any suggestions welcome
Old 08-17-2014, 03:26 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
with motor off, use a rubber mallet to bang on stuff.
sometime when a bolt backs out ( before it falls off) the washer will make a ringing sound.
just make sure all is tight...keep any coins under your gas fill cover? I've seen that.
Mike
Old 08-17-2014, 03:39 PM
piper59's Avatar
piper59
piper59 is offline
Received 1,228 Likes on 625 Posts
Take off your gremlin bells!Yea,I know, smart *** answer. Hope you find it,that would drive me nut's too.
Old 08-17-2014, 04:42 PM
Ol skool's Avatar
Ol skool
Ol skool is offline
Was just about to post the same thing!!! Have heard of alot of guys having the same issue and it turned out to be their bell!!!
Old 08-17-2014, 06:21 PM
Vancebagger's Avatar
Vancebagger
Vancebagger is offline
6th Gear
Have you checked to see if the cam chain is loose? It could slapping against the primary housing.
Old 08-17-2014, 07:36 PM
jayhawkclint's Avatar
jayhawkclint
jayhawkclint is offline
I had the same thing driving me nuts for a while and it turned out to be the gremlin bell.
Old 08-17-2014, 07:44 PM
escalade6103's Avatar
escalade6103
escalade6103 is offline
had this issue on the way back from a 3000 mile trip. aft shifter linkage pinch bolt backed off a bit. a pain to get to
Old 08-17-2014, 07:50 PM
ddm502001's Avatar
ddm502001
ddm502001 is offline
Luckily I am going deaf, higher pitch noises get mauled by other sounds so I don't hear those kinds of things, just have to check the bike after rides for loose stuff. That horrid screeching noise on the back of the bike when the wife rides just disappears.
Old 08-17-2014, 07:54 PM
rkoivisto's Avatar
rkoivisto
rkoivisto is offline
Default That's loose
If your cam chain is hitting the primary, you got a lot more problems than a loose chain. Just sayin
Old 08-17-2014, 08:15 PM
Devo6684's Avatar
Devo6684
Devo6684 is offline
I got the same sounds, like tiny pebbles hitting my front fender. Happened right at 5,000 miles on my '12 Limited. Thought it was bad gas. Several tanks later same issue. It usually occurred at 2,700rpm.
Went to dealer several times and was told it was normal- that it was the 'harmonics' of the valves/lifters. Sounded like an angry cicada in my motor, very annoying. Luckily I had added an amp and speakers to the bike so I was able to tune it out.
Btw- V&H power duals, heavy breather and SE super tuner did not help the issue.
Quick Reply: Jingling noise driving me nuts....help?
